Thread: $62 e-bike
Old 02-06-2020, 01:59 PM   #18 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by hayden55 View Post
Its a generic 1c 18650 chart.
Its something like:
Lower Upper Cycles Capacity
0 100 500 100
6 94 7500 88
8 92 15000 84
10 90 25000 80
20 80 35000 60
30 70 40000 40
Yeah honestly I hear those controllers are all over the place. I'm sure its peak and probably stabilizes down lower.
https://www.batteryspace.com/prod-specs/5457_B4.pdf
Cycle life, according to that, is 300, though that is charging it to a full 4.2 volts. Yes, you'll get more than that, keeping it to ~4.05 volts and not discharging it past 20% remaining, but I doubt it'll be over 1000 cycles. Of course, if you don't use it all the way down to 20% capacity, it'll help. As will keeping the load light on each cell so that it doesn't heat up, which would kill them quicker than rated.
Unless your controller has no speed limit, you will only really see 1500w on hills. The motor will also limit it with the back EMF (voltage the motor generates as it spins), so unless the rim is much too large for it, the voltage being fed in to it will limit the top speed, at which point the power draw will drop off. (though chances are this is pretty high and wind resistance might be enough that you WILL pull 1500w continuously). Oh and don't forget that you'll spend a lot of time accelerating and decelerating, unless its one long stretch all the way to your destination.
Dynamic braking could mean dumping the energy to a dump-load rather than trying to push it back in to the batteries. Would be cheaper and simpler than trying to pump it back in without a regen controller. You could try dumping it in to a voltage booster, which could then push it back in to the batteries, but I'd try a dump-load (large resistor) first. I haven't gotten around to testing this yet.
I've got a 3000w motor off of ali-express. Other than not being well balanced, it is built well enough to handle the power. I'd not put it on any bike that wasn't built like a tank. Your $62 might have been better spent on a used, decent-quality bike.
Hmm. That's all my thoughts for now. Not trying to discourage, looking forward to seeing your budget build.
