Thread: $62 e-bike
Old 02-06-2020, 03:33 PM   #19 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Yup cycle life is a tough one. It looks like the LG cells may get 60% of the cycle life of the Panasonic cells that the table is based on. Also, those numbers are with mild temps ,0.5c charge, and 1.0c discharge.
I finally bought my batteries last night. Going to build a 15s7p pack. Cells ended up being $90.54 (86 cents each).
I definitely say I will get above 1000 cycles, but it may be more based on this chart:
Capacity End V Start V Cycles Usable kWh
100 3 4.2 300 982.8
88 3.072 4.128 4500 864.864
84 3.096 4.104 9000 825.552
80 3.12 4.08 15000 786.24
60 3.24 3.96 21000 589.68
40 3.36 3.84 24000 393.12
I am interested in building my own programmable BMS with an Arduino and some relays, temp sensors, and an ammeter. I would be able to program in all my limits on voltage, amps, and could try out the dump load as well. I can even do some dip switches that swap the program to/from each capacity level for prolonging life. (ie: switch combo 3 = 30to70% capacity range limit) Dump load probably just to do the braking and not charging though. Maybe later.
But we are discharging harder in a hotter environment. Past that I only have a lot of fuzzy math since I don't have any motor curves to work with. I have noticed the motor only achieves so many RPM/Volt so it will be interesting to see how fast we go and how far we go. I ended up spending $40 on the bike so If I decided to sell the bike I wouldn't lose much money if it ends up being lame and slow. Then I could keep my battery for other projects, and sell the rest.
*also the motor has a limiter disable wire.
So far:
$40 - bike
$90.54 - battery cells
$196.15 - 1500w voilamart kit 26" rear wheel
By the way I appreciate all the feedback and advice everyone. Having a lot of fun so far doing calculations and planning config/testing.
Hoping this will turn into a 40 mph e-bike on a new frame with all the safety hardware to be legal.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
