Today I was driving around and hit a big puddle and a pot hole. I got 3 check engine lights, "P1298 P0135 P0141" After some searching it seems to be this
https://catjuggling.com/1996-honda-c...here-is-a-fix/ https://catjuggling.com/wp-content/u...6/x99-029e.pdf
SYMPTOM: The MIL is on with a DTC 20 (electrical load detector), DTC 41 (primary heated oxygen sensor), or DTC 17 (vehicle speed sensor). Fuse 15 in the under-dash fuse box is blown.
PROBABLE CAUSE: The engine wire harness is rubbing on the intake manifold bracket.
REQUIRED MATERIALS: Electrical Tape: 3M P/N 54007-06132
![Turtle](/forum/images/smilies/turtle.gif)
