Old 02-07-2020, 12:08 AM   #26 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
90 day: 19.27 mpg (US)
Originally Posted by Galvatron1 View Post
Just out of curiosity, what's the best mpg an unmodified non-hybrid Camry can get of this generation? I think the absolute best I can get is 60-80+ Mpg on highways for a minute or 2, since the chart doesn't read above 60 mpg. The worst I can get is in city traffic with lots of stop & go traffic, poor traffic light sequences & heavy congestion yields sub 5 MPG. Avg overall is mid 20s mpg.
Not sure what I can do to net gains. I inflate my tires 1-2 psi above the door jam 35 PSI recommendation. Sidewall max PSI is 51. I hope to not induce premature tire wear by exceeding the manufacturers PSI rating. .
How accurate is the Toyota MPG screen?
Honestly it's very dangerous to run a 51 max psi tire at 33psi
it's under inflated
you can have a blow out
as you can see on this tire it's at 32psi Riding the side wall it wore the corners of the tire.
about 40% side wall compression Hot PSI was 36
I put it to 45PSI HOT PSI is 45 0% fuel lost to heat
The Following User Says Thank You to Tahoe_Hybrid For This Useful Post:
Galvatron1 (02-07-2020)
