Old 02-10-2020, 02:08 PM   #23 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by roosterk0031 View Post
Normally don't watch instant MPG much, but I'm single digit with the Cobalt in the first 3 gears with my normal acceleration, shifting close to 3,000. I've decided I'd rather get to speed fairly quickly so not getting single digit or low teen mpg a longer amount of time. The coast on the other end makes a bigger difference I think.
See if you can use a camera to record load, rpm, and gpm. If you have a scanguage like most of it (I thought it was a membership requirement here :P).
That would get you a feel for it. Start off idle at 75% load, 90% load, etc.. and go up to 2700 rpm.
Well I assume a lot of the diy tuner guys probably have a laptop for datalogging and can read the tables. I haven't really gone that far.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
