Old 02-12-2020, 12:45 PM   #8446 (permalink)
aerohead
man
I'm glad you brought that up.
If the ocean heat lags for 80 to 100 years how can any climate change be attributed to man? Or at the very least any ocean changes?
100 years about we had "eighteen hundred and froze to death" and the Dalton minimum.
The only scientific explanation for global warming,outside of natural variability,is anthropogenic greenhouse gases.
If you'll resolve the volume of ocean water into pounds,and then calculate the amount of Btu's necessary to increase its temperature 1-C,you'll have an idea of the thermal inertia we're talking about.If you worked at a power plant,this would be a routine calculation.
There's no scientific connection between the Dalton Minimum and global climate.
NeilBlanchard (02-13-2020)
