Originally Posted by wyatt
I would by no means say it's a "show stopper", but have you considered putting the phone jack and the USB on the same side of the setup? It would make mounting in an enclosure much simpler since you only have to get it up tight to one side.
If the connectors were rotated 90 degrees, both cables could insert from the bottom. Of course, it's never that simple.
