Old 02-19-2020, 07:51 AM   #28 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Originally Posted by serialk11r View Post
I think the answer is it affects efficiency quite a bit, but it's got a bit of a negative feedback loop built in.
Thin oil has less viscous drag, which means it heats up less at the same temperature and load. Thick oil has more, so the friction heats it up and brings up the temperature, lowering the viscosity. If you have very effective oil cooling and a large sump with thick oil, you're definitely losing fuel efficiency in a noticeable way.
Some engines are built with bigger bearing tolerances so they need the high viscosity. As far as I can tell, it's better if you don't need to rely on this effect, e.g. F1 engines which run a 0 weight or something (but they also need to be pre-warmed). Putting thicker oil in an engine built for thinner oil is only useful if you can't keep the oil temp under control in severe load conditions, e.g. pouring some 50 weight in at a track day if your oil temps are like 300F.
I recall reading on bobistheoilguy.com quite the opposite. (no personal experience).
The explanation was that if you have thinner oil, it flows more removing more heat.
