Time. The pumps and circuitry have to stay powered up twice as long on 120v.
Conversion efficiency. There is a slight efficiency boost trying to convert 340vdc up to 360 to 400vdc to charge over 170vdc.
170vdc is about what you get from rectifying 120v, 340vdc comes from 240vac.
The same resistance losses for double the power. 12 amps is 12 amps, the wires don't care if it's 120 or 240. Assuming a both circuits run the same size wire.
It appears the biggest efficiency boost comes from reducing time the charging system stays powered up.
So a 16 amp 240vac evse will be more efficient than a 12 amp 240vac evse.
