Old 02-21-2020, 01:56 PM   #19 (permalink)
NeilBlanchard
Are you coasting in neutral? If you are going faster than 7MPH, you can bump the shift puck into R, and it will go into neutral - or, you can hold it in N for about 2 seconds.
If you are going less than 7MPH, don't shift into R - as it will go into reverse!
You have to shift back into D to get any regen; even on the brake pedal.
Flakbadger (03-05-2020), MetroMPG (03-04-2020)
