Old 02-23-2020, 12:34 PM   #2 (permalink)
oil pan 4
It was already wired up for 240v but someone had a 120v plug on it. I bet it worked really good.
Rebuilt triplex or general pumps run around $250.
It will never pay for its self with gas savings.
I might see if a cheap gasoline engine pump will fit on there. I can take the one off my gasoline pressure washer. It has a 7/8 shaft. I can at least see of the gasoline and 56C face motor holes are the same, I think they are. The 56 frame motor has a 5/8 shaft. So I won't be able to test it.
