Thread: 2007 Camry SE
Old 02-24-2020, 12:01 PM   #2 (permalink)
serialk11r
36 could be difficult in some driving conditions. The 2AZ is working against you a bit since it's so old, but you could try an underdriven crank pulley. Another area to gain a tiny bit is the power steering, you can decrease the system flow rate at the flow control valve to reduce its power consumption at the expense of slowing down the steering rack a little. Maybe manual torque converter lockup?
The Following User Says Thank You to serialk11r For This Useful Post:
Taylor95 (02-24-2020)
