Old 02-29-2020, 09:19 PM   #19 (permalink)
serialk11r
I'm fairly certain BMW uses EIVC, but I suppose there also have infinitely variable lift.
It doesn't seem unreasonable to be to have two cam profiles, perhaps one very low RPM profile with a switchover as low as 2500RPM, which is intended for EIVC.
That's right, Multiair, Valvematic, Valvetronic, and VVEL are EIVC, since they reduce lift and duration together.
What you see with the Honda R18 and K20C2 is 1 LIVC and low lift cam and 1 normal duration cam. The R18 would use the normal cam all the way to the rev limit but the K20C2 uses the big cam at >6100rpm for powah.
LIVC without excessively high lift is better for pumping losses than EIVC since you draw air through a bigger opening, and there's also a little less negative work from compressing air heated by the cylinder walls. Ideally, you'd be able to close the intake valve at 300 degrees ATDC while idling.
