Old 03-03-2020, 10:35 PM   #5 (permalink)
Flakbadger
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Originally Posted by sgtlethargic View Post
I believe I've heard on this forum that aerodynamic cars have stability issues. Is that true? How so? What can be done about it?
Thanks
I mean if you look at a regular bicycle vs a velomobile, you'll find that the aerodynamic fairing on the bike makes it vulnerable to lateral winds, which is why most velomobiles are tricycles instead of bicycles. Here's a quote from the wikipedia article on them:
"The fairing on a velomobile sometimes makes it more subject to cross-winds than a similar unfaired cycle. The effect of cross-winds is complicated because the force of the wind can act as a steering force, as-if the rider had tried to steer the cycle. "Wind steer" can be a safety issue and may also hurt performance, as a serpentine path is longer and thus slower than a straight line. Thus, a design with inferior aerodynamics may be better overall. For example, it is common for time-trial bicycles to use a solid disk rear wheel for best aerodynamics, and a spoked front wheel that has worse aerodynamics than a disk, but is less likely to steer the bicycle in a cross-wind."
Something like a boattail that increases the length of the vehicle substantially could very well affect lateral stability from crosswinds, but I feel like the majority of mods centered on streamlining will not have a negative effect, since most of them focus on the front profile of the vehicle and decreasing the trailing wake.
The Following User Says Thank You to Flakbadger For This Useful Post:
aerohead (03-04-2020)
