Old 03-05-2020, 09:55 PM   #110 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Engine is out of the metro. This thing is SUPER rusty! I was trying to avoid going underneath the car because of it, but I ended up having to go underneath to undo the rear mount and I ended up cutting the shift linkages because I didn't want to be pounding on the thing trying to get the pins out. I also figured that they would most likely need to be modified to fit the mercury anyway.
This was one of the more solid areas of the car and after I put the car on the stands and the front wheel on a cinder block I pushed the car as a precaution and the stands started going through the floor Once it stopped I put the jack back in contact with the only section still intact on the side of the car.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
Gasoline Fumes (03-05-2020)
