Old 03-05-2020, 11:42 PM   #47 (permalink)
Flakbadger
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Test fit of L side ABS
Cut one of the templates out of a piece of my scrap ABS, used my heat gun, and bent it. The pen mark is still vaguely visible, I have spraypainted it with 2 coats but it needs a 3rd tomorrow. I did this because I am trying to get experience with the material before I go hacking away at the wheel skirt piece and destroy a dozen dollars worth of material.
The posterboard template (top) and the cut ABS plastic piece (bottom).
Here it is slapped in briefly. Will need a bit of adjusting still but I am happy with the result.
Later I'll attach this permanently with screws and L-brackets inside the bumper to make sure it doesn't go anywhere. For now I'm just test fitting. Turned out pretty great so far. Right side tomorrow. Onward and upward!
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
The Following User Says Thank You to Flakbadger For This Useful Post:
aerohead (03-07-2020)
