The data and anaylis in the second pdf don't seem to agree.
Look at the HP rating through out the range and the non grooved head is almost always higher sometimes dramatically.
The testing was also flawed because the data on combustion chamber size is smaller for the grooved head. If that is correct the grooves must be destroying the combustion process to lose that much HP.
I only skimmed the report and noticed those.
