Greenflight, that's a very nice electric powered truck you have there
. And I don't mean that just because it is the venerable and generally rare Ranger clone
. I don't doubt that thing will last for longer than the electric motor you put in it. But then again what does it weigh with all those batteries loaded into it? And a heater is required, for all vehicles. It's like an unspoken law of life, lol. If you could install a 600 watt electric coil heater that could be plugged into the wall and turned on prior to starting a trip then it could most definitely maintain the temp inside your cab for a good distance without battery power. If you travel even 20 minutes in below 50 degree weather it could very easily pay back in better winter health and the comfort value. The electric coil with oil inside are very cheap but all the one's I've seen are about 9"-12" wide, 2 feet tall, and 18" long, plus they're heavy and bulky. They wouldn't fit inside your cab without giving up your passenger seat. But the biggest trick would be how much power would it consume to maintain the cab temps. Plus all the wiring to plug it into the batteries.
Is that $6000 for the truck and all upgrades including the EV conversion components? I can see how much the batteries lowered it
my ranger looks jacked up compared to yours.
Shame about your motor burning up. This may sound ignorant of your current motor's capabilities but shouldn't you try running it in 3rd or 4th as your only forward gears? With the highest torque supposed to be at 900-1100 rpms and continuing all the way to max rpms, do you need to use more than one or two forward gears?
Ah well excuse me for being overcurious. It's good to see at least one person my age doing something truly unique and positive
