Old 03-12-2020, 08:24 PM   #8 (permalink)
racprops
Well there are a number of Scan Gauges IF you don't mind getting your MPG from the OBDII Port. I have two versions: https://www.ebay.com/sch/i.html?_fro...cat=0....these are fine and well made. and as a cheaper version but seemly a little more complex is: https://www.ebay.com/sch/i.html?_fro...kw=turbo+gauge
This is a new one, looks interesting.https://www.ebay.com/itm/12V-OBD2-Ca...UAAOSwUrZd8ggE
The only need for a MPGunio is IF you tricking the car's PCM to improve its MPG and it some cases you might trick the MPG readings as well. Which is why I have them.
Rich
