Your mom sounds irrational enough that you'll get a different answer if you ask the question on a different day and slightly reword it.
Given your neighbors, using the trailer to get around building codes will probably be worth your while. And if you build the shed right, you can take it with you. If you build it so that you can jack it up off the trailer, you may find that a trailer can be useful in the meantime.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
