Old 03-15-2020, 01:47 PM   #17 (permalink)
EcoCivic
Originally Posted by ksa8907 View Post
The only detriment I can think of from having too large of cooling lines is the extra time it will take to move more fluid. More of a cycle time issue than anything else I would imagine. But honestly, it's not going to cause a problem. Using smaller hoses from the factory is also cheaper which is 99% of the reason for their selection.
Thanks. By extra time you mean it will take longer for the fluid to fill the hoses and start circulating once the engine is started? If so that's not a problem since the returning fluid isn't going anywhere except back into the sump, nothing is relying on it for lubrication or anything like that.
