Old 03-16-2020, 12:23 AM   #3 (permalink)
leoblack9
tinker
Ideal pot hole tire appears to be largest over all diameter, as wide as practice with a large aspect ratio for lots of side wall.
Right, so this is a vote for 155/80/r13 I assume? Thank you for your advise. Its the tallest sidewall tire I can find for the 13" rim size
The only downsides I see to it is incorrect speedometer reading and slightly less acceleration due to a wider diameter over OEM spec.
