So why cant diesels run gasoline instead?!
I mean they can start in colder climates much better because of the lower flash point of gasoline, and they can burn and work much cooler and waste less energy in the form of heat... ??
Sure, they can just drop the compression a bit I suppose, but wouldnt gas be better for lets say colder climates and just not running so hot...?
