Old 03-19-2020, 12:41 PM   #9 (permalink)
redpoint5
90 day: 29.78 mpg (US)
I did replace the sender at one point thinking that the damage the previous one sustained may have been the cause. Some bolts had come out in the differential and caused a bit of damage on the tone ring and scuffed up the plastic on the sender.
The crazy thing is the heads were sheared off on some of the bolts, and the diff still functions.
I should probably sell the motor and scrap the truck. The body has probably 350,000+ miles on it, the headliner is massively sagging, the AC stopped working long ago, the speedo/odometer doesn't work, and therefore the cruise control doesn't work, the wiper motor recently failed and was replaced with a weak unit, the windshield seal let loose near the bottom so you can see the glass pop out whenever you close the door... the front end never did track straight except for a few months after replacing the U joints and track bar. The transmission was weak from the day I got it, and now it locks/unlocks at a certain speed around 53 MPH. The calipers need work again.
Still, it pulls a trailer whenever I need it to.
