Old 03-20-2020, 01:19 PM   #13 (permalink)
freebeard
A 72 Dart.
Aha!
What I am not hearing is, and I still seeking, can you take a somewhat low pressure likely turbulent air pocket, and "suck it" enough to change the direction of nearby streamlines closer to where the air pocket was?
The low pressure wake makes fingers that reach into any incipient turbulence and pulls backward on the rear of [your Dart]. If you apply power to the duct sucker, it will pull wake 'forward' limited only by the power you can supply.
I know, still not what you want to hear.
