Old 03-23-2020, 07:21 PM   #168 (permalink)
oil pan 4
In most places the box that goes through the wall outside needs to be at least 2 feet above the ground. I think that's national code.
That's the main one, any inspector is going to see that.
And no plastic insulation bushings were used on the inside of the RMC and EMT connections, If your inspector is former nazi ss they will make you pull all the wire back out and install the insulating collars/bushing.
Going from the inside box to the outside box I always connect the boxes together with RMC.
