Old 09-18-2008, 10:04 PM   #2 (permalink)
Daox
Here is something I came up with a while back. Input your info into the yellow fields to get the info. It tells you money saved via mpg increase. You could simply subtract the cost of the mod from the savings to get an estimated answer.
You can use or ignore the second set of info. I simply duplicated it because I have two main vehicles.
gas_calc.xls
