My experience with modern(ish) fuel systems is as follows
1) Tank yes crap accumulates here, not much, but some. Mostly Varnish, and oils which alcohol is good at cleaning out . . .
2) Pump Inlet screen I've never seen one plugged, I'm sure it happens . . . .
3) Fuel pump
4) Hose
5) Filter (mostly rearmount, or under the vehicle)
6) Tube to front
7) Fuel rail
8) Injectors tapped off fuel rail
***** Some cars such as new neons end here they use pwm controllers on the fuel pump to eliminate the FPR + Return hose**********
9) Fuel pressure Regulator
10) Return line to pump.
And the fuel keeps flowing. . . . Rund and Round like a record
Are you implying that absorbed water in the ethanol mucks up paper filters?
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
