Old 03-28-2020, 11:51 AM   #854 (permalink)
Piotrsko
If you're still mostly factory stock, run it from the fuse panel back then up through the driver defroster vent plastic eyebrow then under the front window rubber up to wherever around the mirror. Make a bracket that mounts to the mirror mount screws. 1/8" hole in the defroster eyebrows wouldn't hurt efficiency.
Disregard if you've got a round window super.
freebeard (03-28-2020)
