Just what I've read:
When shops change the fluid they typically use a pressurized pump that goes in the opposite direction of flow when the engine is running. This knocks debris loose and causes this issue.
Whether this is true I don't know, but if you want to change it I would recommend disconnecting a cooler line and let it pump a quart or two out. Turn the car off. Add the same amount. Rinse and repeat until the fluid coming out of the cooler line is clean.
I don't know if this applies to all A/T's, because of the cooler location in the flow path.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
