Old 04-01-2020, 01:05 PM   #303 (permalink)
The Toecutter
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
What speed are the tires rated for?
Originally Posted by arcosine View Post
Bicycle tires are not speed rated.
The manufacturer rates the Schwalbe Marathon Plus tires at 50 km/h continuous.
https://www.schwalbe.com/en/tour-reader/marathon-plus
I currently have Schwalbe Marathon Greenguards installed that are rated for 25 km/h, but they are due for replacement and I will be using the Marathon Plus.
Bicycle highway speeds or automobile highway speeds?
I'll be able to top out around 60 mph, but I won't be doing it very often, given the risks associated with pushing to the limits a vehicle whose parts are not DOT rated. Most of my use case will be around 30 mph, with a bit of 40-45 mph cruising on occasion.
The idea I have in mind is a vehicle that can perform like a pedal-powered velomobile with the motor completely disabled. I'm hoping I get the aerodynamics good enough that under pedal-only, I can reach 40 mph on flat ground. With the motor enabled, the long term goal is to perform like a sports car, while getting the equivalent of thousands of miles per gallon. My current KMX frame will get me part of the way there, but not entirely. With the parts I have and parts I plan to get, it will perform like a slow to normal car from 0-30 mph. It has served well as a learning experience and is soon to be a functional proof of concept. It will be very usable at city traffic speeds and over long distances on back roads and bike trails.
In the long run, I will be building another vehicle capable of holding highway speeds with stability and with components rated for it. Perhaps go with 16" light-duty moped rims all around with some Mitas MC2 low rolling resistance tires rated for 100 km/h. But I'm going to need a custom frame for that, with stronger wheel hubs, thicker axles, stronger spindles, longer wheelbase, hydraulic brakes, roll cage, ect. I'm confident I can keep such a vehicle under 100 lbs, but it will take careful attention to detail, and I need to learn how to weld titanium. At its core, it will still be a bicycle, albeit a heavy one, and I want it to be ridable like a velomobile(faster than a normal bicycle) with the motor disabled. This vehicle may end up capable of reaching triple digit speeds and doing 0-60 mph in like 4 seconds using the electric drive system(possibly 2 motors in a FWD config or even 3 motors in an AWD config), at least that's the theory. Got to build this first prototype first!
The Following User Says Thank You to The Toecutter For This Useful Post:
freebeard (04-01-2020)
