I made an engine stand for the engine. It seems pretty stable, but the front of the engine is only held up by a single post. I was running out of material to build out of so that's the best I could come up with. I left the engine together when I built the stand so all the wrenching I did on it didn't break it, so
. I left the hoist hooked up with some slack just in case.
Since I undid the timing belt already and removed the transmission (and therefore the starter) I couldn't do a compression check. Instead I did a leak down test and all cylinders were within 5% of each other (33-38%) based on a HF leak down tester. I will probably remove the oil pan and then redo the leak down test so that I can better tell if the leak is through the rings or the valves. I am also thinking about sending in some of the oil to see if it tells me anything.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
