i pumped up the 4 tires to 44PSI
i think a good mod would be for the hood gap stripping it tends to flap around in the wind... you can see the hood get a little bit of lift and flex i'd assume this is causing drag...
seems to keep in auto stop much longer with it pumped to 44psi i had them at 40psi before
should i block off the lower or upper portion of the grille (have to be careful as i have an aluminum block)
