Even though the rear live axle would presumably make it harder to get a full belly pan, I'd give it a try. Rear diffusers might help a lot too. Messing with smaller mirrors is something I wouldn't be so comfortable with, but maybe it could be worth if their aerodynamics is better. For smaller vehicles I'd often recommend the ones out of some sports motorcycle which usually have a more aerodynamic housing, but maybe if you set them a little further back than stock position it may not be so bad at all.
