Old 04-08-2020, 01:18 PM   #6 (permalink)
Chonk_Master
Crosstour - '11 Honda Crosstour EX
I'll definitely consider playing with tire pressure, now that you framed it that way. 🤔 I'll definitely look up Capri's post. I'm at 33 out of 44 psi, I'd be flabbergasted if I didn't lose some traction between here and there but, like you said, there could very well be some room for no-cost improvement. If I only I had a skidpad......
*looks at empty Walmart parking lot*
And yeah, springs would come after everything else. I did find some from Megan that aren't expensive and may be worth it to experiment. The tricky part is no one makes just a spring for the Crosstour, explicitly. Everyone I've seen lowering Crosstours gets the Accord spring with the highest spring rate, which I think is for the V6 hatch from the same year. So, I'd need to be able to get spring rate specs on the spring, which shouldn't be too hard.
And I'll look up those instantaneous MPG apps because what the heck. I've been using the VCM eco light as a bellwether for now. 😄
