Old 04-11-2020, 04:48 PM   #61 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The dead IMA battery I received when I sold my good battery has been in the car as winter ballast. A charge/discharge/charge cycle didn't help. I decided to take a closer look at it and found one bad stick (there are 6 "D" cells in a stick) with probably just one bad cell in it. I looked through the pile of sticks from my other Insight and selected the one with the highest voltage (4v, the rest were 3.5v). After charging it, the voltage looked great at over 8v. I installed the stick in the pack and I have a hybrid again! I'll check the voltage taps after a while to see how balanced it is now. Except for the tap with the bad cell, the tap voltages were all about the same. The battery revival was easier than a complete IMA delete, and I don't have to climb hills at 3500 RPM in 2nd gear now! I need a clutch switch again. $300 Insight, sold battery for $700, fixed dead battery for free!
I also got rid of 90% of the bucking. Replacing the TPS did not help. The EGR valve from my other Insight seemed to eliminate most of the bucking. I'll order a couple of new valves. I don't understand why blocking off the EGR didn't stop the bucking. Maybe my block-off plate wasn't sealed well.
I installed a new radiator. The original one was losing its fins and I expected it to start leaking soon.
I tried installing a block heater. I thought all Hondas took the same heater, so I just bought the cheapest one. Now I know it's all Hondas except the Insight. Different thread pitch! I'll have to order one from Honda.
I made a grill block that covers the non-radiator side of the lower grill from the back. Nearly invisible.
The soft snow tires on heavy steel wheels are off. Now running proper RE92s up front and some other 175/65-14s in the rear. As I posted earlier, one of my mounted RE92s blew up. And another was developing a tumor as well! I have a set of good used RE92s that I'm going to put on Insight donut wheels. What color should I paint the yellow donut wheels?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
