Old 04-13-2020, 08:34 PM   #22 (permalink)
freebeard
And I'm open to cutting springs, just because I know you can, but you can get a nice, high spring rate set from Megan for about $150.
I've dropped two Superbeetles. I sold one on, and when I did the 2nd one I requested the shop use the same (stock) spring rate but increase the anti-roll bar. Instead they used super-stiff springs and the stock anti-roll bar.
When the opportunity presented itself, I had them replace the stiff springs. With the stock spring rate and 3½" of clearance, the only real problem is ground strikes on freeway bridge aprons.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Chonk_Master (04-13-2020), Ecky (04-13-2020)
