For just an EVAP line, you can probably figure that one out yourself, but it speaks to a broader issue certainly.
Yeah, there's probably already a youtube video on it, if it starts throwing a PO442 code I'll check it out. The letter said the entire process could take up to - and I quote specifically from the letter - 50 minutes to inspect and up to 12 hours and ten minutes to replace the evap hose
I've swapped motors out in less time than that!
