Old 04-19-2020, 01:16 AM   #220 (permalink)
JulianEdgar
The sensors were located in the middle of the undertrays.
The electronic suspension system is easily set up for differing rakes but what I have seems to work pretty well, so I have left it. At my normal ride height (5 on the dial) it turns out I do have a lower front than rear clearance. (It must be only at '1' on the dial where the rear gets lower than front - and I never run '1' on the road.)
Yes I like the copper wire space frame modelling - but you wouldn't believe how that story was denigrated when it first appeared!
freebeard (04-19-2020)
