Old 04-23-2020, 08:37 AM   #103 (permalink)
Daox
12mm is very close to 1/2". Also, 19mm is very close to 3/4". If the heads are these sizes its very easy to use imperial tools on them.
A metric drill bit set would be a good idea. However, I've always been able to just print a nice snug fitting hole for almost all my 'threaded' holes. This is just the smallest hole I've ever had to do that with. I did test print it a couple of times, but I probably could have tested it once more!
The Following User Says Thank You to Daox For This Useful Post:
Ecky (04-23-2020)
