Bigger turbo if you drive long distance on a motorway or autobahn, cold air intake for when air temperature is above about -5C, use bigger intake pipes with smooth bends, install an intercooler if you don't have one, use a block heater.
Bigger turbo: is it really that effective? I'm afraid it may increase consumption. The standard turbo has a variable geometry so the blades are adjusted depending on the engine load to deliver the best flow at every engine speed.
Intercooler is also standard and has it's own inlet, as seen on the picture of the front.
