Does anybody use common sense around here. Im sorry to be rude but im in a bad mood. the tires are just standard tires ( i really hope i dont have to waste even more time getting every tire size for each tire) yes the diameters get bigger as you go up in size, but as the tire gets bigger, u change gearing to keep the rpms equal. therefore if one tire seems to be better than another, you would change gearing till u ended up with the best tire, and the best gearing.
