Old 04-29-2020, 11:44 PM   #18 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Ironside View Post
If you can't extend the existing gear change , you could try a hand operated 'suicide shift'. Rear brake can be made hand operated by using a pitbike clutch lever and a scooter rear brake cable of the correct length.
What about the CombiBrake system now fitted to some small-displacement Honda motorcycles? It's now fitted to a similar model in Brazil. With some adjusts, single-lever operation could be improved.
