Do you have brake drag reduction springs?
Looked it up ont YouTube. What a great invention! And quite easy to do myself. Thanks for the tip!
Originally Posted by ptitviet
Nice post!!!
Is there any additional potential in your car by changing final gear ratio? What is your RPM at 80km/h for instance? Lowering rpm will result in an increased engine load and therefore a better fuel efficiency.
1500 rpm at 80 km/h or 50 mph. Lower rpm's in highest gear and a slight ascent of the road are causing the engine to hum. So given the standard engine output (~80 hp) 5th gear is long enough.
The cheapest way to extend the gears is to increase the tire size.
The Fabia has a 195/55 tire which is too wide and too small. Next tire could be 175/70 and would result in 1400 rpm at 80 km/h.
