Old 04-30-2020, 09:55 AM   #4 (permalink)
redneck
I like your method.
Plus, using a Honda Insight with its high mpg capabilities, expands the scale of resolution to see and discern subtle differences more easily.
Are you going to try testing smooth wheel coverings too ? They will most likely fall below your 2% threshold but, they might move the needle enough to gain a little Insight. (pun intended )
Looking forward to your results as you test the various aspects of automotive aerodynamics.
