Old 05-03-2020, 02:18 PM   #166 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
My next thought was, what if all healthy and youngish people adopted that mentality? What if we took healthy volunteers to purposely expose themselves to The Rona, then quarantine for 2 weeks?
I would volunteer for that. We're shut down for at least the rest of the month, and my job involves a lot of contact with older folks. Might as well have it, get it over with, and reduce the likelihood of passing it on unknowingly when things open back up.
As it stands, I don't know if I've had it or not (my partner had all the symptoms but tested negative in March, but I've recently been reading that the tests could have as high as 30% false-negative rate). I've had a couple bouts of sore throat/stuffy nose in the last month so I'm hoping it was My Corona and not just allergies or something.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
redpoint5 (05-04-2020)
