No real updates to the project. I've been busy trying to get all my class work done for the end of the semester. I did clean the car out, pulled a few more dash panels and the carpet. I also put the passenger seat back in along with the floor mat. I only found a small rust hole in the floor about finger size.
I did however decide to do a psuedo drive to work (I was furloughed) today since it was nice out (about 70 F 45% humidity 12 mph wind SE, trip was E-W). I drove there like usual. I got 45.65 MPG, previous best was 42 I think. I stopped in the empty parking lot at work and sat there for a little bit to let the mpguino reset. While doing that someone pulled into the lot took my picture and when I waved at them they hurredly did a U-turn, stopped took another picture, then sped off
. By the time they left the gauge had reset. I then took off for home. So a hot start. I EoffC PnG'd and went under the speed limit when someone was behind me. Until the end of the drive back when someone was behind me and didn't want to pass
. I of course got stopped by the last light before my house
. I ended up with an impressive, but not good enough trip of 55.54 mpg. I was on track to break 60 until the very end
I saved the hand brake lever from the metro and I am going to try and make a hand throttle with it. I also bought some cheap lowering stuff for the car should be ~2 inches drop. Finally, a question: there is some sort of ceramic insulation, on the floor of the car. It also seems to be collecting dirt and moisture and causing rust. I should be good to remove it correct? I can take a picture and post it if need be. There was some on the floor of the metro as well and that is where most of the rust was.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
