Old 05-03-2020, 11:26 PM   #113 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by M_a_t_t View Post
Finally, a question: there is some sort of ceramic insulation, on the floor of the car. It also seems to be collecting dirt and moisture and causing rust. I should be good to remove it correct? I can take a picture and post it if need be. There was some on the floor of the metro as well and that is where most of the rust was.
It's sheets of tar-like insulation. I've removed it from a few cars. Could be around 10 lbs or more. If you're lucky, it'll pop off the floor in big pieces. Cold weather can help. Or it might come off in little pieces. If you're unlucky, you'll have to scrape it off with the help of a heat gun.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 3 Users Say Thank You to Gasoline Fumes For This Useful Post:
California98Civic (05-16-2020), M_a_t_t (05-03-2020), Xist (05-04-2020)
