Old 05-06-2020, 10:50 PM   #38 (permalink)
EcoCivic
What engine management are you using with your cam and mods?
If you haven't remapped your fuel tables (and to a lesser extent your ignition timing values, as they're fuel dependent), they're probably a mess.
I'm unfortunately using the ECU that came with my JDM Honda Stream VTEC engine and it's not programmable. It's just a stock Honda Stream ECU. There are 2 aftermarket options available for these engines: Kpro and AEM EMS. Kpro isn't an option because I have an auto and AEM EMS isn't an option since I can't afford $1300. Other than that it would be a nice option though, I could use it with my D17 now and use it with a K24 in the future when I swap.
I don't think the mods I did messed anything up too badly though because my MPG is no worse than stock and performance has greatly improved, so it is still an improvement even though I'm probably not getting the most performance or efficiency possible out of my mods.
