Old 05-07-2020, 08:48 AM   #69 (permalink)
Yippeekyaa
Goldie - '11 Toyota Prius
90 day: 48.93 mpg (US)
Originally Posted by JulianEdgar View Post
There is possibly a way of doing this with electronic throttle.
  • You will need two people, flat and straight road, decent speed update OBD data.
  • Drive car at constant speed eg 100 km/h. You will probably be able to do that more accurately than the cruise control, but see which is better.
  • Passenger reads actual throttle blade position (or total engine load if such a figure is available).
  • Figure needs to stabilise eg less than 1 per cent variation as you hold speed constant.
  • Repeat test and make sure figures are very close.
  • Open all windows. Go back over same stretch of road with all windows open.
  • Maintain same speed.
  • Read what actual throttle blade position (or total load number) now is.
If the blade opening or load number has distinctly increased, then you have a base reading for what causes a major (eg typically 12 per cent) change in drag.
If that is the case, you have a go / no go indicator for aero mods - so long as the change with the aero modification is above the variation in the readings at a constant speed.
However, do not apply any maths to attempt to work out percentage changes - too hard when throttle blade position / load number is probably not linear with power (or torque).
(And I wouldn't do it with the Prius yet, in case electric power is also changing.)
Let us know how you go!
The obdfusion app does have engine load and engine torque output options, it also has a performance option that measures that is similar to drag racing timing system but uses actual data from the obd port. I will experiment with engine load parameters and see what happens. Thanks for the idea.
